Assalam-o-Alaikum, i need a suggestion for a sports car 4 door possibly , under 50 lac, which is reliable, pretty and is not too old, and has decent poweri have to modify it over time too.
If Your Looking For RWD Best Car is Under 5 Million you can Get An E46,JZX90
Don't know about good fuel average but get a Mark X swap in an LSD and it'll be a great daily car you can slide around.
Wailaukum AssalamAccord Cl9 Manual with some Ecu modes.
thanks, but want a small, and fuel efficient car probably 13km/l +avg
Turbo Civic fits the requirement
Civic X hatchback might fit your requirement as well. It's a bit smaller than the sedan and has a 1.0L turbocharged engine. But I'll give you the same advice I've given you before and that would be to buy a daily driveable car and a project.
older suzuki are good
Swift Liana Margalla Baleno
All can be swapped to 1800cc
i have seen many suzuki khybers proving to be reliable pocket rockets with an engine swap and some mods to the chassis .. so consider khyber as well.
Their bulkheads tear off from the frames though, so anything other than its factory engine options are a bit iffy. Unless you literally build an engine cradle for it.
try Datsun 1200 solid car parts are available can be modified my son has modified a datsun 1200 pickup model 1980s reduced its height and replaced its engine with 1900 EFI not sure which one. installed roll cage and support to chaise its light weight and does donuts without any efforts.
check internet or search for floor 8 and you will find my sons vids i think its the only datsun pickup modified for such purposes.
Jzx90, mazda Rx8 with 1/3uzfe or 1/2jz
I've seen your son's car in person and I have to say that it's a beautiful project.
you have not seen my VW beetle model 1965 rebuilt a couple of years ago its a classic and is one of the best beetles in Karachi. i will not claim its the best as there are better ones with a lot of investment. i had limited budget did the best
project is almost complete with wiring and dash to be installed. not my taste but a teenager will love its looks.
I think I've seen your beetle as well. I'm not sure but I think I saw you with your son on 14th August Gentleman's Club Drive. I came with Team Nayyer in Razi Uncle's Fintail.
