I have 2005 Altis which has done approximately 65000kms on the clock. Recently, I am noticing a vibration which starts at 30km\h and ends when the speed reaches 40km\h or above. The vibration is noticable when i do hard acceleration but on gentle acceleration its not there. The vibration seems to be shaking the whole car. I have done balancing and alignment but the problem is there. The mechanic suggests that the problem lies in wheels but i am still in a state of ambiguity. Any suggestions will be highly appreciated.
Same was the problem with me.... vibration between same speeds u mentioned..... Get ur axle check, their end toward gear box might have developed some problem.... Don't worry, it's not a big issue
check your axels .. they might have developed problem .
if u feel ur car makes more noise than it should but does not accelerate like it should and u have slight vibration in the initial speed that means "clutch plate khatam"
likely cause is axle problem...........
its an axle problem.
And also check one thing APP KI GARI TYRES KHAA RAHI HOO GI. The design on ur car`s tyres is getting erased day by day.If this is happening then immediate attention is needed. Ur axle rod surely have a problem.
i bought 1.6 altis 2012 model , the very same problem with me , mechanic says axels needs to be check , please guide me is that true?
