Same here buddy and I only have independent research on this matter which I did from various forums and website on the internet. I'd love to hear input from someone who's an expert and has done some mods to a 4x4 vehicle
Same here bro I want to put them up soon, will update once its done. You can go for foam cell if you have 50% off road drive or carry lots of load
I dont carry extra load but have to travel north and love to explore new tracks and places twice a year or go to desert other than that mostly travel on paved roads but if foam cell is as good as nitrogas on road but better offroad and also wont effect height then i will go for foam cell Anyways first hear from you if it is worth the upgrade or not
That’s great. Waiting for your feedback regarding the shocks, so that i can go ahead and get them for my car as well.
Hi, would like to know at what milage Sigma 4 diesel filter should be changed? Toyota islamabad recomended between 20K - 25K. Any expert opinion - Thanks
It's been 4 days Rupee has depreciated from around 265 levels and Toyota Indus hasn't yet bumped up Fortuner prices by another 10 lacs? What's happening Indus guys!!! Apparently, getting lethargic.
So I have a Revo and I have lifted front suspension as I like the stance of a lifted truck. It's now completely level with back. I have done so using only the spacers. Spacers have given additional suspension travel as well. There is one point to consider here i.e. ABS lines. The ABS lines only have a limited give when the suspension is lifted and on full articulation the lines get stretched. One can either unbolt the abs line from its fitting to get extra play but its not recommended as the line can get crushed and result in loss of ABS. These lines can be extended as well. I have not done so yet as Hilux is a 3rd car so i can wait until i have ample knowledge. If anyone has lifted a 4x4 and has same issue as me please let me know what have you done to counter it.
Salman bhai changing shocks will not increase the height of the vehicle, adding spacers or springs will. I don't think ABS lines should be an issue with just swapping shocks
Spacers can increase ride height but not suspension travel
Brake lines etc is okay till 2-3”
I change my diesel filter every 15K. If you use STP diesel fuel treatment with every tank and get your diesel from a trusted station, you can stretch the filter to 20-25k. Otherwise best to change it every 15k.
That is true because the length of spring remains the same.
My ride is around 3-3.5 inch higher than before and the abs lines are stretched on full articulation and on the hydraulic lift. The brake fluid lines themselves are all ok and have enough give.
Yup, if no spacers or springs are used then the height will be the same and so will be the brake line situation. No ABS line steching concern.
If your ride height is 3-3.5 higher than stock did you change your tyre specs?
My car has 285/65s on it so yes its not factory as the originals look small with lift.
Utter garbage Indus Motors quality. AC gas leaked entirely after just 3 months of owning Legender.
What was the diagnosis?
They replaced o ring seal and refilled gas. Lets see if it works.
That's utterly disappointing. 15 mil worth a vehicle
