i want to know that is modified cars are reliable or not
like swap the engine and other lik low profile rim and sespension
wating for the expert suggesion
Depends. If you spend money on quality stuff and don't take your car to the "local ustaads", then it'll be reliable, otherwise, not so much.
bro i have swaped my charade with 4efe toyota 16 valve engine 1300cc is it reliable
You can just stick to same thread and asking all queries there.
yes ....if its done properly
so babban welding the axle rods to cups and sheeda making wooden mountings and then lektrishann nitto taping the wiring so 1 pulse fires 4 injectors and a radiator made from recycled rust, filled with salt water and engine filled with fake API SB 30/40 can take me from karachi to naran in one shot nonstop?
What? I lost you after the first line.
when ever you change the originality of the car it gets weaker .. remember .. so stick to original . it may work for sometime but eventually will breakdown often
